Results 1 to 10 of 13
- Sep 2008
- 120
October 18th, 2011 12:56 AM #1Quick question to the folks here. I have been experiencing intermittent engine vibration/idling on my 2008 Altis whenever I do a full stop. This happens particularly on heavy traffic whevever I am on a stop and go situation. This does not happen often but I am concerned that this might lead to something more serious. I have actually asked assistance from the casa but the technicians were not able to catch the vibrating during the road test. Please provide your ideas on the issue.
October 18th, 2011 02:15 AM #2
Can you explain on what kind of vibration? if it's like a long shaking motion whenever you're from a stop, the cause for this will more likely be the Engine Mounts Supports or Transmission Supports. maybe either is already defective. You should replace the mentioned parts ASAP if these are confirmed culprits.
have your car checked at a certified Shop.
THE AUTO SPECIALIST
- Mar 2006
- 607
October 18th, 2011 04:26 AM #3you may have an engine misfire , get it checked as soon as possible .
- Nov 2008
- 641
October 18th, 2011 09:01 AM #4Chief,
Question, is your car automatic? If yes, during the engine vibration, are you still engaged in the "D" or drive position? What if in Neutral, do you experience the same?
If manual, better check your idle speed sensor.
Try also consulting other certified casa's. Thanks
October 28th, 2011 08:13 AM #5
Mga Sir,
If the car is A/T, might need to check your idle. May want to have the Servo cleaned or Idle adjusted.
Got the same issue with my Accord. Magpaplinis pa lang po ng Servo.
Many thanks!
- Mar 2014
- 355
November 24th, 2017 06:18 PM #6Thanks uls for fixing my car and saving me a lot of money. Last night i noticed my 2011 Altis' engine sounded rough and there was noticeable vibration at idle. The vibration was worse when i shift to R or D, at idle, brake applied. Driving it felt less powerful and rougher than before. Brought the car to the shop this morning and quoted me a ton of stuff and i had to leave my car. I called uls to ask him if replacing all those parts were necessary and he said "wtf". Brought the car to uls and they fixed it in an hour! These are only the parts replaced:
November 24th, 2017 06:51 PM #7
ano name ng shop casa ni uls?
November 25th, 2017 11:22 AM #9
November 25th, 2017 11:44 AM #10
