Results 1 to 9 of 9
    Apr 2013
    Mga ka tsikot! May katanungan lang ako. Kanina kasi habang nagmamaneho ako, nag stop yung makina ko. (4G62B) Familiar yung sound so I was expecting something really bad happened. Pinabatak ko yung jeep ko sa mekaniko namin then pag open ng valve cover at pag redondo, ayun hati si camshaft. Second time na nangyari ito sa akin. About 4 or 5 years na rin. That time madami akong karga nun pero ngayon wala naman. Baffled yung mekaniko namin bakit nangyari yun kung di naman na stress masyado yung makina at di naman spirited driving yung ginawa ko. Matic trans siya then yung isang kaibigan ng mekaniko namin nabanggit niya, di kaya dahil sa bigat nung kaha ng jeep at syempre matic trans medyo yung return feedback nung torque converter sa makina heavy stress yung binibigay. Yung kaha kasi ng jeep ko full stainless ay medyo on the thick side. Suggestion ng mekaniko ko palitan ng makina na Diesel. Sabi niya RF Engine from Mazda kasi madali hanapin yung parts at in terms of performance okay siya. Eto naman yung mga tanong ko.
    -50k yung estimate na magagastos ko for the engine swap. makatarungan na ba yung presyo na yun?
    -talaga bang maganda yung RF diesel engine na mazda in terms of torque and power?
    -aside from the engine ano pa yung maaring palitan pag nag swap?
    -pwede ko ba i trade in yung old engine ko para sa i-swap na makina then mag add na lang ako.
    -is changing the engine to a diesel good for the long run pag daily driver yung car?
    TIA
    Aug 2004
    Camshaft or Crankshaft? The camshaft is non-load bearing, so it should not break.
    If the crankshaft is shot, then that's an expensive rebuild. Makes more sense to buy a new engine.
    How big and how heavy is your jeep? Owner type? Jeepney? Long jeepney?
    Apr 2013
    Camshaft sir. kasi nung pag redondo namin habang walang valve cover, yung valves lang sa piston 1 and 2 yung may action yung 3 at 4 wala. Owner jeep yun at mahaba siya. Sing haba nung Dmax namin. Yung gross weight di ko alam pero i know medyo mabigat siya dahil sa thickness nung kaha na gamit. Sabi nung mekaniko namin pwede pa naman palitan yung camshaft kaso medyo mahihirapan maghanap kasi madalang na yung ganun klase na makina sa surplus. Sabi rin kasi nung mekaniko namin na Diesel parts might be pricey but worthed naman since they're built to last as long maganda yung maintenance. Di ko kasi mabitawan yung jeep because of sentimental value kaya selling it would be the last option.
    Aug 2004
    4G62B ba? Second time a camshaft broke? Peculiar, pero considering the age...
    Rather than the RF route, I would first check to see if a 4D56 would bolt up the the 4G62B transmission (as both are Mitsubishi motors), which would lower the cost of swapping significantly. The 4D56 also has the added benefit of widespread parts availability and easy maintenance.
    Apr 2013
    Yes sir. 4G62B yung makina at second time na nangyari. Sabi nga nung mekaniko namin ang weird. But my uncle said consider the age of this engine. baka naghahanap na talaga raw nung kapalit. Sabi nga ng mother ko buhusan ko na raw ng gasolina at sindihan! hahaha! Pero yung suggestion ninyo sa 4d56 ill ask our mekaniko if possible or need to fabricate adapters for it. Thanks sir sa suggestion.
    Apr 2013
    May nag bigay sa akin ng suggestion earlier this evening. Isuzu engine ang ilagay ko raw. A bit cheaper sa RF engine na mazda raw. He told me to get the Isuzu C190 from a light elf truck. Its around 25k Php already with a transmission. Any insight on this mga sir?
    May 2009
    yun pickup ko formerly 4G54B ngayon e 4D56 turbo. bolt on lang sa auto transmission. di rin nagpalit ng engine mounts. ewan ko lang kung parehas sila ng bolt pattern sa 4G62B.
    pero swinap eto ng former owner ng sasakyan ko.
    Apr 2013
    Quote Originally Posted by miked View Post
    mukhang di raw pwede yung 4d56 sa auto trans ng 4g62b. pero check pa rin namin if pwede. sayang yung transmission eh. yung pinag tanungan ko eh pinoy surplus na 4d56 na unit. around 35k yung price with transmission na. pero sabi ng mekaniko namin mas maganda if japan surplus instead pinoy surplus dahil rebuilt lang yung mga pinoy surplus. sana mabigyan ninyo pa ako ng insights ninyo para mas malinawan yung isip ko at makapag decide ng tama. TIA mga ka tsikot.
    Jan 2018
    UP.UP.UP. I own an escape which was swapped from V6 to CD20 (standard, crappy engine). Would it make sense or better if the engine be swapped again to a CD20T (Turbo)? Would it make any difference performance wise?
Engine Swap Query. From Gasoline to Diesel
