Results 1 to 12 of 12
    Oct 2008
    Hi,
    Does anybody here know a reputable shop that can do this? its an old converted mitsubishi RVR.. any inputs will be much appreciated.. Thank you
    Feb 2012
    Search niyo po sa Facebook
    Gas to diesel innovation
    Jan 2011
    RVR is front wheel drive. diesel with transverse engine is quite difficult to find.
    look and asked around in banawe.. there is a shop there that does convertions for Gas powered cars to be replaced by a diesel engine.. i cant remember the name of the shop..
    Jan 2008
    Quote Originally Posted by shelu View Post
    may mitsubishi RVR na diesel A/T.
    Jan 2011
    yup. meron po sir, kaso hard to find.
    Im looking for a shop also. Pero engine swap lang. May reco ba kayo malapit sa Makati?
    Jul 2013
    For clarification, anu bang gusto engine swap?
    Iba kasi yung i-convert mo yung engine from gas to diesel. This is similar to converting gas engine to LPG which common.
    But gasoline to diesel is very impractical.
    So I am assuming engine swap lang ang gusto.
    Jan 2018
    UP.UP.UP. I own an escape which was swapped from V6 to CD20 (standard, crappy engine). Would it make sense or better if the engine be swapped again to a CD20T (Turbo)? Would it make any difference performance wise?
    Jul 2013
    Quote Originally Posted by TalkTalk01 View Post
    sorry, Ford Escape?
    I recommend a bigger engine.
    If you can put the Ranger's turbo diesel engine on an Escape, that would be great. Or you can consider the 2.0L turbo diesel engine used on the older Focus TDCi.
    However, you need to make sure that the tranny is compatible or you have to do a tranny swap also.
    Jan 2018
    If you can put the Ranger's turbo diesel engine on an Escape, thatwould be great. Or you can consider the 2.0L turbo diesel engine used on the older Focus TDCi.
    Mukhang mahal po masyado yun sir. Nabasa ko kasi na either Mazda or yung CD20 nga. May nakakaalam ba kung malaki ang diperensya ng takbo ng CD20 at CD20T and kung kaya ba ng Turbo ang body ng escape?
Converting gas engine to diesel
