Results 1 to 5 of 5
    Mar 2003
    how would you know if your car's engine supports need replacement already?
    thanks in advance!
    :nerd:
    Nov 2003
    check the rubber around the support. if there are cracks or kung humiwalay na ito sa metal then this is a sure sign na kelangan palitan. pwede mo pa-solid pero this will make the ride very harsh.
    normally, you will only be able to see the left and right supports while the tranny support has to be checked from under the car.
    Mar 2003
    so wala dapat clearance between the rubber and metal support, walang space para mag-play yung rubber sa loob ng support?
    thank you sir!
    :nerd:
    Try jerking the vehicle in 1st gear, pag may secondary jerk motion galing sa harap bitaw na yun. Or kung minsan nararamdman pag idling malakas ang nginig ng makina.
    Nov 2003
    hard to explain eh pero dapat nakakabit pa yung rubber sa labas and walang crack. if you want bring it to the shop and check namin for free if buo pa sila.
Engine Support
