check the rubber around the support. if there are cracks or kung humiwalay na ito sa metal then this is a sure sign na kelangan palitan. pwede mo pa-solid pero this will make the ride very harsh.
normally, you will only be able to see the left and right supports while the tranny support has to be checked from under the car.
Originally posted by speedyfix check the rubber around the support. if there are cracks or kung humiwalay na ito sa metal then this is a sure sign na kelangan palitan. pwede mo pa-solid pero this will make the ride very harsh.
so wala dapat clearance between the rubber and metal support, walang space para mag-play yung rubber sa loob ng support?
Try jerking the vehicle in 1st gear, pag may secondary jerk motion galing sa harap bitaw na yun. Or kung minsan nararamdman pag idling malakas ang nginig ng makina.
hard to explain eh pero dapat nakakabit pa yung rubber sa labas and walang crack. if you want bring it to the shop and check namin for free if buo pa sila.
