Originally posted by speedyfix
check the rubber around the support. if there are cracks or kung humiwalay na ito sa metal then this is a sure sign na kelangan palitan. pwede mo pa-solid pero this will make the ride very harsh.
normally, you will only be able to see the left and right supports while the tranny support has to be checked from under the car.
so wala dapat clearance between the rubber and metal support, walang space para mag-play yung rubber sa loob ng support?
thank you sir!
:nerd:
