Results 11 to 13 of 13
April 2nd, 2016 10:55 PM #11
Can you do 3krpm on 1st 2nd and 3rd gear? If the 4th gear is the only gear that is limited maybe there is a transmission issue. Last atf change? Manual transmission sabi mo earlier. Now its triptonic(tiptronic is the correct term).
- Apr 2016
- 130
April 2nd, 2016 11:22 PM #12oops my bad sir its automatic / tiptronic po pala sorry sir newbie lang, actually its a repossessed bought it from a lady since hindi daw nagagamit binenta na, I didn't know that last ATF change since 1 month plang sken, and pansin ko dn mejo, hnd mlakas ung throttle nya to be honest, pero nabasa ko kc since hnd ganon kalakas horsepower niya,
Also, pag nag sslow down ako from the 3rd gear nilalagpasan niya ung 2nd gear, pag almost full stop then shift agad sa 1st gear. any idea po?
- May 2017
- 15
May 8th, 2017 05:47 PM #13mga sir maya katanungan lang ako. meron ako problem sa Lancer GTI 1992 EFI engine 4g15
pansin ko pag idle siya ng lalaro ung ung idle nya. minsan nmn steady lang siya tapos may time na bumagbagsak ung idle nya tapos aangat ulit pero since nka muffler ako hndi swabe ung tunog nya sa muffler parang may misfire na tunog parang may maliit na naputok sa loob ng chamber pero okay nmn ang takbo ko. ska pag naibyahe ko na ng 4hours straight may time na biglang mamatay ung engine nya. tapos need ko mg wait ng 2-3 mins bago siya start ulit.
additional problem is umaamoy ung gas nya sa tambutso. and every start ng engine meron white smoke na nalabas na amoy gas.
hndi ako ng babawas ng oil and coolant. FYI
salamat sa sasagot
Xiaomi E-Car
