finally had it checked out by a kapitbahay's mekaniko. tune up lang daw ang kelangan. he made some adjustments to the distributor/ignition, cleaned the contact points/rotor, ok na -- for a time.
but after the test drive bumigay din ung contact point. luckily i still had a spare orig at home. seems to have run perfectly after it was replaced. advise din niya to replace the condenser soon.
not really sure what caused the contact point to break down though; i've driven a lot farther prior to today, hindi naman bumigay. kung sabagay, i don't really rev the engine that hard; siguro nagbreak down na siya with the higher than usual revving/current going through it
medyo kinabahan ako while he was troubleshooting and revving the engine hard; me naririning akong loud pops coming from the engine. sagot lang niya, sa timing lang daw ang problema
um, anybody wanna buy some slightly used sparkplugs? B)
