maybe you can help me or redirect me to a similar page...
Picture ito ng 5K engine ng Toyota Liteace, 1991.
This faces the engine
(o-ring in place):
(o-ring removed):
Side view:
This part faces the radiator(o-ring removed):
Hindi din ako sigurado kung "engine pulley" tawag dito, kaya nag attach ako ng pictures. Siya kasi yung pulley na naka-attach sa main engine kung saan naka hook lahat ng belts para sa aircon, alternator at power steering kaya nag-assume ako na engine pulley siya.
Maingay kasi yung makina pag start, at yung dahilan, natanggal na yung isang pulley. May "goma" daw yung "o-ring" na nakahiwalay (serves as clutch). Pag wala daw makitang spare nito, puwede daw gawin, weld directly yung natanggal na "o-ring".
Ok lang ba ito? I think may dahilah kung bakit clutched yung pulley at baka may masamang mangyari pag i-weld directly. Hindi ko din alam kung anong belt ang naka-attach sa o-ring na ito, kaya wala din ako idea kung bakit dapat clutched siya... Hindi kasi ako kasama ng tinanggal nila at din maalala ng tatay ko kung ang belt na naka-attach.
Crankshaft pulley po tawag dyan... Main pulley that drives all the other pulleys...
Usually pinapalitan po buo yan... There's a tremendous amount of torque generated between the inner and outer ring ng pulley, di O-ring lang pinapalitan.
Ang function nyan ay to absorb minute engine vibration.
The rubber is vulcanized between the outside ring mass and the inner ring which has a key way to locate to the crank. The vulcanized rubber allows the outer ring to counter act the crank vibration.
If you weld the outer ring to the interior mass you will eliminate this function. The result will be a two piece crankshaft(broken in two).
ma feel mo vibration though not that evident. when starting the engine malakas palag ng engine, kahit flip mo accelerator ma feel mo yun "shock" sa engine.
Yung crankshaft pulley ng Accord ko, pinawelding ko na lang. Medyo short sa budget kasi, and kailangan nang gawin kasi malapit ng kumalas. 1.6k lang ang lahat vs. 3.7k for replacement and labor.
In my case, very negligible naman ang engine vibration. I couldn't tell the difference, and so far wala pa namang negative incidents na nangyayari (more than 1 year na).
kung iweld mo sya ng direct,mawawala yung torque axis ng crankshaft and pulley,which is bad for the crankshaft itself kaya mararamdaman mo yung malakas na vibration at higit sa lahat hindi mo na mahihigpitan sa tamang tension ang mga belt nyan,kasi yan mismo ang nagsisilbing tensioner ng belt.
sir pwede weld yan dami na namin nagawa na ganyan basta dalin nyo lang siya sa machine shop para naka align kung kayo lang kasi meron talagang vibration will cost you around 300 pesos pero kung mechanic ang magdala mas mahal kasi meron percentage ang mechanic sa machine shop (50% to 60%). Yun crankshaft pulley kasi ng civic dati bumili kami ng surplus wala na siya rubber....
