Originally Posted by
bullet
hi! t'was my 1st time to do a DIY change oil on my 99 intercooler turbo starex. after having drained the old oil from the pan, changed the oil filter and air filter, i proceeded to fill the engine with fresh oil. after only filling about 4 liters (the manual says oil pan capacity alone is 4.9 liters), i checked the level with the dipstick and i was petrified that the level was about an inch above the full mark. what are the dangers, if any, of overfilling? i tried to dry up the pan by draining again the oil from the pan but the level is still above the full mark. lessons i've learned: not all of the old oil is drained when changing oil; and jack up the car when crawling underneath! your two cents worth please! thanks!
