Originally Posted by kinyo opo meron tool kailangan ... kahit anong wrench basta sukat sa drain plug Di po kaya mabuhos lahat ng langis, when use the drain plug? Salamat mo sa advise.
Bigat paa :grin:
Saken sir Minsan NASA 2k stable mga 2to3 minutes mag up and down need pa re start para maging...
In my car idle on coldstart was 2k high need 2 to3 mins to be restarted the engine to get the...
Normal po Yan saken inde bababa need pa re start everybody can share same as my experience so I...
Enter your email address:
Delivered by FeedBurner
high idle RPM at engine start
