Results 1 to 8 of 8
- Sep 2019
- 23
October 26th, 2019 10:39 PM #1Good day po mga katsikot, pa-advice po sana ako.
may nakita kasi ako engine oil leak, bandang baba ng valve cover kasi so ang hula ko is either sa spool valve galing or sa may o-ring ng camshaft thrust cover.
bale pinaestiamate ko po muna sa isang sikat na car care center dito sa province namin at ito po estimate nila sakin, ok lang po ba price (especially sa pcv hose)? fyi, replacement parts daw po, not oem.
this monday nagpasked na rin ako sa casa for 2nd opinion, hopefully mas mababa price or equivalent with oem parts.
estimate
salamat po
October 27th, 2019 07:09 AM #2
is this pcv hose between the pcv and the intake side? why does it need changing?
also the leak is because you probably have a bad pcv causing overpressure and leaks. this pcv needs changing every 24-36months.
- Sep 2019
- 23
October 27th, 2019 10:11 AM #3
- Sep 2019
- 23
October 27th, 2019 10:13 AM #4Tale note that only gaskets and o rings to be replaced on the image not the assembly/parts
- 54,258
- Jul 2014
- 31
October 28th, 2019 10:23 AM #6
November 16th, 2019 05:19 PM #7
November 16th, 2019 05:23 PM #8
Baka wala pang ₱100 o-ring sa auto supply.
Means "Sedan" in japan... Sakanila yung civic na 1997 may ferio sa ilalim nang civic na logo at...
Civic horsepower
