Results 1 to 8 of 8
    Sep 2019
    Good day po mga katsikot, pa-advice po sana ako.
    may nakita kasi ako engine oil leak, bandang baba ng valve cover kasi so ang hula ko is either sa spool valve galing or sa may o-ring ng camshaft thrust cover.
    bale pinaestiamate ko po muna sa isang sikat na car care center dito sa province namin at ito po estimate nila sakin, ok lang po ba price (especially sa pcv hose)? fyi, replacement parts daw po, not oem.
    this monday nagpasked na rin ako sa casa for 2nd opinion, hopefully mas mababa price or equivalent with oem parts.
    estimate
    salamat po
    is this pcv hose between the pcv and the intake side? why does it need changing?
    also the leak is because you probably have a bad pcv causing overpressure and leaks. this pcv needs changing every 24-36months.
    Sep 2019
    No explanation from the this car care center, but based on my research, these highlated parts are the once they will be replacing
    Sep 2019
    Tale note that only gaskets and o rings to be replaced on the image not the assembly/parts
    Quote Originally Posted by ozzy0408 View Post
    estimate
    salamat po
    go window-shopping, sir.
    ask the auto parts stores, how much they cost.
    then input the labor...
    Jul 2014
    estimate
    salamat po
    sir, maiba lang ako, ilan years na honda city mo ?
    estimate
    salamat po
    just had my cam thrust o-ring replaced sa honda casa...850 lang price ng o-ring. yung sa quotation na post mo 1,850. mahal
    Baka wala pang ₱100 o-ring sa auto supply.
engine oil leak on Honda City
