Results 1 to 10 of 10
- 59
January 19th, 2003 12:07 AM #1mga bosing san pa ba pede manggaling ang leak ng oil
sa bandang gitna pong engine.
salamat
- Nov 2002
- 194
January 19th, 2003 02:00 AM #2baka sa distributor cap yan...o-ring lang yan...not sure though if you have the same case...
- Dec 2002
- 124
January 19th, 2003 11:36 PM #4My car also has a leak under the engine. Near the junction of the engine and the transmission. Saan kaya nanggagaling iyon ? Oil Seal kaya ?
- Dec 2002
- 21
January 20th, 2003 02:49 PM #5i tried using engine degreaser (bought sa ace hardware) and soap and water. Nang malinis na saka start engine, then look where the oil leak is coming from. Kaso yung crankshaft oil seal ata, kailangan tanggalin ang timing belt cover kasi nasa likod siya ng timing belt.
- 59
January 20th, 2003 04:24 PM #6maraming salamat po sa reply
mejo malakas na po leak nung sa engine ko d na kailangan linisin para makita kung san nag flo-flow... sabi ng isang mekaniko na pinag tanungan ko bka daw sa cylinder headgasket... simple lang ba pag ayus nun? kaya na ba to sa mga simpleng talyer lang?
salamt po ulit
January 20th, 2003 07:13 PM #7
ey this is my first post...
anyway, i think u shud check the ff: valve cover gasket, crankshaft oil seal and the oil pan gasket. one of them might be the culprit. hth!
- Jan 2003
- 16
January 21st, 2003 04:36 PM #8Dudes by years of maintaining cars the usual cause of oil leak underneath is worn out C.V. oil seal, Orig part ave.price is Php250.00ea. and labor is Php250.00ea. mga 2hours rin abutin palit nyan, ipa-re-grease mo narin yung CV joints mo (CV grease is Php55ea tube) per joint consumes 5 tubes.Gudluck Dude...clone:roll::DDudes by years of maintaining cars the usual cause of oil leak underneath is worn out C.V. oil seal, Orig part ave.price is Php250.00ea. and labor is Php250.00ea. mga 2hours rin abutin palit nyan, ipa-re-grease mo narin yung CV joints mo (CV grease is Php55ea tube) per joint consumes 5 tubes.Gudluck Dude...clone
- 27
January 22nd, 2003 11:59 AM #9karlo,
deng kung cylinder head gasket lang eh pwede na DIY na dyan. All you need is the gasket (baka mga 500) plus silicon sealant. Kung gusto mo sabay mo na rin gaskets to the sparkplugs.
Goodluck!
- 59
January 27th, 2003 02:36 PM #10ok na ung leak ko pinagawa ko na po.... sa head gasket nga nanggagaling ung leak so pag ka replace wala ng tagas =)
haaay salamat sa Dios ok na.... at mga kotse peeps salamat po sa mga reply at suggestions nyo!
Xiaomi E-Car
