Results 21 to 24 of 24
November 5th, 2004 11:22 AM #21
So I would assume Delvac1 failed from your own oil preference?
Isn't that a good sign that the oil viscosity is higher than what it should be? Better engine parts protection.
Tsikot Member Rank 3
- Dec 2002
- 636
November 5th, 2004 02:01 PM #22So I would assume Delvac1 failed from your own oil preference?
A degraded base oil won't have enough protection while a highly sooted oil may cause increased wear metals. Think the best protection is from properly spec'd oil, doing what it was designed for.
November 5th, 2004 06:32 PM #23
Got it, thanks for the clarification.
I did read somewhere that recommended oil from owner's manual for a particular engine should not always have the most advance ratings. Sample, recommended CG rated then used oil is CH or CI is not advisable? I wonder if this applies to all engines?
Would those Delvac1 oils be sold *300/lliter?
- Dec 2002
- 636
November 6th, 2004 08:19 AM #24I did read somewhere that recommended oil from owner's manual for a particular engine should not always have the most advance ratings. Sample, recommended CG rated then used oil is CH or CI is not advisable? I wonder if this applies to all engines?
So for japanese engines, I look for an oil that has higher TBN, ash (oil specs based on product data sheets) so not solely based on the API rating.
Xiaomi E-Car
