Results 11 to 15 of 15
Tsikot Member Rank 5
- Nov 2003
- 3,849
March 16th, 2008 11:52 AM #11bad rings or valve seals will show by causing a lot of smoke when you rev the engine.
price to replace the parts depends on the engine and what else needs to be done.
- Jan 2008
- 380
March 28th, 2008 09:23 AM #12
March 29th, 2008 05:45 PM #14
ganun din nangyari sa akin datin...pero mas malala sa akin...every week ako nag checheck ng dipstick ko...parati sa kalahati yung oil level ko...wala namang tagas or smoke...
nag canvass ako kung magkano pa OH, 30k+, hinde nadaw kaya sa top OH, kaya i decided to change my engine...30k + 20k, wala na problem oto ko...bulsa ko nalang...
pero worth it talaga...
pero pag nagtitipid ka...pag hinde pa na Top OH yan...try mo pa Top OH baka kaya sa ganun lang...or baka naman valve seal lang yung culprit...
the best steps is pa check mo kay sir speedyfix...2 hands up ako sa service nila...mura na..pulido pa...hehehe
- Nov 2003
- 3,849
Saken sir Minsan NASA 2k stable mga 2to3 minutes mag up and down need pa re start para maging...
high idle RPM at engine start
