Quote Originally Posted by box_type View Post
here's the story of the 36 km travel i had last saturday,
-a/c is on, at the 10 km mark i noticed temp is a little bit high above the normal range so i stopped by a gasoline station and let the engine cool down a little bit and when i opened up the radiator i can't see water inside so i poured water in it and it consumed about more than 2 liters of water, so that means water was not completely drained...
- i continued driving and again on or about the 20th km mark again temperature starts to rise again so i stopped again in a gasoline station and added more water with the same amount as before...
- again continued driving and the same thing happened but this time i did not return the radiator cap thinking that it would be quicker for me to pour in water in case the engine heats up again, and just as i thought the engine heats up again and I continued doing this routine until i went back to my starting point...
-yesterday, i poured water in the radiator and checked it this morning and lo and behold! water in the radiator is still full to the brim! so maybe i can now surmise that there's no hole in the radiator (which i have been thinking all along) or there's no problem in my cooling system, right?
so, here's the question, what could be the problem with my engine? because all along i thought my radiator was the culprit...
and oh, by the way car is toyota corolla 16v 1990 model with 4af engine
Change your radiator cap first with the same or a little higher pressure rating. Use a quality coolant. Run your engine until it reaches operating temperature enough to activate your fans. Observe for leakage to trouble shoot....
