Results 11 to 18 of 18
Tsikot Member Rank 4
- Jun 2006
- 2,605
October 6th, 2006 11:11 AM #11actually I drained it overnight para sure. even the trany oil na drain ko narin....
October 6th, 2006 11:12 AM #12
kung due for replacement na ang oil filter mo ..sabay mo na din palitan
- Oct 2005
- 72
October 6th, 2006 11:15 AM #13thanks; actually na drain ko na iyon engine oil at iyon trany... pero hindi ko pa ntry start ... pina tutuyo ko pa iyong mga connection at comp box para sure....
thanks for all your advise...
October 6th, 2006 11:19 AM #14
sir mike_0197 meron na pong mga related topics tungkol sa Flushing Oil...makakatulong po ang search function natin sa susunod...maraming salamat po ;)
Engine Oil Flush
http://tsikot.yehey.com/forums/showt...r+flushing+oil
Engine Flush ? ? ?
how often should you engine flush and add additives??
Using engine flush
- Oct 2005
- 72
October 6th, 2006 11:29 AM #15Mikbik;
got your e-mail info about the flushing.... thanks appreicated.
October 6th, 2006 01:11 PM #16
October 6th, 2006 02:07 PM #17
Also make sure you use the correct oil. Gas engine oils have API-S ratings while diesels have API-C ratings. Para masmadali, S is for spark while C is for compression. Our diesel has been used with API-S rated oil early in its life, wala naman problema. Not sure if the reverse would have no effect.
Tsikot Member Rank 5
- Nov 2003
- 3,849
October 8th, 2006 07:41 PM #18kalokohan to overhaul kung walang problema! what kind of mechanic is that?
Without more context like when was the last time these items were serviced/replaced, it's hard to...
