Results 1 to 10 of 18
- Oct 2005
- 72
October 6th, 2006 09:02 AM #1Mga Sir;
Need your help to give us idea.
Kung mag papa change oil ba, is it better to use first the engine flahsing oil... please correct me if I'm wrong.
Can you advise how to use this in correct procedure...
Makakatulong ba ito para malinis loob ng engine bago i fill up new engine oil,
lalo na those soaked in flood.?
Please help me ......
thanks/
October 6th, 2006 09:09 AM #2
I just find it a waste of money. Just fully drain the oil and replace at regular intervals.
- Oct 2005
- 72
October 6th, 2006 09:35 AM #3what if the engine soaked in flood.... doest it mean need to overhaul ? what indication if the engine insides are affected ?
Or should i drained the engine oil overnight .... ?
thanks in advance
- Oct 2005
- 72
October 6th, 2006 09:46 AM #5yes flushing oil, better bang gamitin iyon flushing oil then the normal engine oil para malinis, becuase the car soaked in the flood...... just want to make sure malinis iyon loob ng engine ..... para hindi na overhaul...
kasi halos lahat ng mekaniko sinsabi pag nalubog sa flood kailangan overhaul agad.....? it seems need to fully drain the engine ? is that right?
sorry if my post quite confusing....
October 6th, 2006 09:52 AM #6
the supposed to be function of a flushing oil is to "flush" out carbon deposits inside the engine. which is also the function of newer oils in the market. may mga cleansing properties na din kasi ang mga oils natin ngayon.
so if you really follow the regular oil change intervals as what otep said. you don't need it.
and kung nabaha ka, what you can do is to have your oil changed...yun lang...
- Oct 2005
- 72
October 6th, 2006 10:04 AM #7happy gilmore ,,, actually I drained it overnight para sure. even the trany oil na drain ko narin....
thanks for your advise.
October 6th, 2006 10:13 AM #8
October 6th, 2006 10:23 AM #9
The only time you need to open up an engine involved in a flood is if it was operating and has ingested water (hydrolock).
Overhaul is about replacing/repairing faulty parts and seals. One does not really open an engine up just to 'clean' it. It's the oil's job to do the cleaning. If you want to be sure, load your engine up with ordinary engine oil first and replace with your usual engine oil after a few days' use. Parang nag-gargle lang.
- Oct 2005
- 72
October 6th, 2006 10:40 AM #10Doc Optep ... thanks, actually one of my friend told me to use the ordinary oil and let start...... then after drain again , just what you said ..gargle then replenish with new engine oil.
The reason why I ask if need to overhaul becuase some mechanic once they heared the engine soaked in flood , overhaul agad.
I know if the piston and valve are at rest or hindi naka on angengine all vlavle are close ... right? it means talagang drain ang gagawin , thanks for your good info. really appreciated.
kaya lang iyon interior ko need to clean all the carpet.... grabe...
thanks.
