I have a Kia Sephia 95 LS and I hope you guys can help me out with my issue.
The main issue is that initially, the engine is able to start. Then after a few minutes, give or take 10 to 15, the engine suddenly dies out. The car is no longer able to start after this. I am able to hear the "redondo" but that's about it.
I had a clutch replacement and top overhaul before this happened. The mechanic who did the servicing on my car checked the fuel pump and ignition coil and said that no gas nor current is coming out on both. He then mentioned that this could be an issue with the ECU/ECM. Is this true? I was under the impression that if that was the culprit, then the engine would not have been able to start in the first place. Any inputs on why this is happening?
Any help on this would be greatly appreciated! Newbie nga lang po pala. TIA mga sir!
[/SIZE]
