Results 11 to 13 of 13
Tsikot Member Rank 5
- Nov 2003
- 3,849
July 20th, 2008 10:56 AM #11if you don't have a check engine check the fuel filter and throttle body. baka either or both are barado.
July 24th, 2008 02:17 AM #12
I've seen in your info that your ride is a Lancer MX, kung Lancer nga, probably it's the idle issues of Mitsubishi which is the never ending 'Servo' problem. Much preferred ko na ipa-check/diagnose mo muna sa casa yan before consulting other mechanics para lang maka siguro ka.
Click for more info.:http://www.mymitsuph.com/index.php/topic,201.0.html
- Nov 2003
- 3,849
July 27th, 2008 10:26 AM #13if it's the servo, try having it cleaned rin muna. baka barado sya. if it doens't work then bite the bullet and have it replaced na.
high idle RPM at engine start
