Results 1 to 10 of 13
July 16th, 2008 10:37 AM #1
Tanong ko lang kasi yung auto ko pag nag-start ako ng makina, umaandar naman pero namamatay-matay. Nagtry ako taasan yung idling pero ganun pa rin, merong cycle from high revs to low revs, tapos me chances na mamamatay yung makina. Di ko alam kung may dumi sa air passage o wala sa timing yung makina. Help pls. Thanks in advance
- Jan 2008
- 380
- Jan 2008
- 380
July 16th, 2008 11:30 AM #4Baka madumi IAC(Idle Air Control) valve at IAC valve passage ng kotse mo.
Yung hose papunta sa MAP sensor pag nabunot ganyan din.
July 16th, 2008 11:34 AM #5
July 16th, 2008 11:38 AM #6
If you are feeling lucky, try spraying some carb cleaner into your intake manifold (after removing the filter).
Though if you are unsure - it's best to have it diagnosed and fixed by a mechanic.
__________________
bigbigcar.com Comparison: Hyunda Veracruz versus Mazda CX9
July 16th, 2008 11:39 AM #7
__________________
- Jan 2008
- 380
July 16th, 2008 11:54 AM #9
THE AUTO SPECIALIST
- Mar 2006
- 607
July 17th, 2008 07:37 AM #10your system is computerized ,these things have to be performed ;
scan test for codes and work out with the codes if any.
if no codes present , check fuel pressure, vacuum leaks, compression test maybe. with the help of engine electronics diagram , perform some pinpoint tests to some main sensors. good luck
Traffic!
