Results 1 to 13 of 13
    Tanong ko lang kasi yung auto ko pag nag-start ako ng makina, umaandar naman pero namamatay-matay. Nagtry ako taasan yung idling pero ganun pa rin, merong cycle from high revs to low revs, tapos me chances na mamamatay yung makina. Di ko alam kung may dumi sa air passage o wala sa timing yung makina. Help pls. Thanks in advance
    Jan 2008
    Computer controlled o de-carburador?
    Quote Originally Posted by youngrider View Post
    computer-controlled na po
    Jan 2008
    Baka madumi IAC(Idle Air Control) valve at IAC valve passage ng kotse mo.
    Yung hose papunta sa MAP sensor pag nabunot ganyan din.
    Baka nga ganun, madali lang bang linisin yun? Or kelangan sa talyer dalhin? Medyo lagpas one week ko kasing di nagamit yung sasakyan eh
    If you are feeling lucky, try spraying some carb cleaner into your intake manifold (after removing the filter).
    Though if you are unsure - it's best to have it diagnosed and fixed by a mechanic.
    __________________
    bigbigcar.com Comparison: Hyunda Veracruz versus Mazda CX9
    __________________
    Jan 2008
    Provided, yun nga problema, pwedeng pwede na DIY.
    Quote Originally Posted by mazdamazda View Post
    __________________
    Sir yung filter na tinutukoy mo, yung air filter ba? Pasensya na medyo newbie ako.
    your system is computerized ,these things have to be performed ;
    scan test for codes and work out with the codes if any.
    if no codes present , check fuel pressure, vacuum leaks, compression test maybe. with the help of engine electronics diagram , perform some pinpoint tests to some main sensors. good luck
    Nov 2003
    if you don't have a check engine check the fuel filter and throttle body. baka either or both are barado.
    I've seen in your info that your ride is a Lancer MX, kung Lancer nga, probably it's the idle issues of Mitsubishi which is the never ending 'Servo' problem. Much preferred ko na ipa-check/diagnose mo muna sa casa yan before consulting other mechanics para lang maka siguro ka.
    Click for more info.:http://www.mymitsuph.com/index.php/topic,201.0.html
    Nov 2003
    if it's the servo, try having it cleaned rin muna. baka barado sya. if it doens't work then bite the bullet and have it replaced na.
engine cycles from high rev to low rev until it stalls
