Results 21 to 30 of 45
- 179
December 18th, 2003 09:56 AM #21i have a car which i use coolant and another wherein i don't. ive noticed in the car with the coolant that the engine temp varies with outside temp, at night the meter does not reach the middle area as compared with the one without coolant na palagi nasa gitna, any suggestion? should i start putting coolant in both?
- Sep 2003
- 81
December 18th, 2003 10:47 AM #22what specific brand of coolant do you guys use? what would be the best there is in the market?
December 18th, 2003 11:03 AM #23
DO NOT INTERCHANGE RED COOLANT WITH GREEN COOLANT.
If you're car uses green, stick with it. If it is red, stick with red. Marami pa din namang brands na pagpipilian among the two types. Just a friendly reminder.
xox,
Too many factors to consider, like thermostat condition, fluid flow in radiator core, etc. You should put coolant because it will extend the life of your waterpump and cooling system in general. Do not judge your cooling system by merely looking at the temperature gauge.
- Aug 2003
- 125
December 19th, 2003 09:43 AM #24> i don't think using 100% coolant will cause the engine to take a longer time reaching operating temperature. pure ethylene glycol has a higher boiling point, but that won't mean the engine will take longer to reach the proper temperature (since the operating temp of the engine isn't dictated by the boiling point of the coolant; the engine doesn't reach proper operating temp by boiling the coolant).
i stand corrected and you're right. the engine cooling system has its own temp threshold that activates the circulation of the coolant or water mixture. thanks for the info!
Tsikot Member Rank 5
- Nov 2003
- 3,849
December 19th, 2003 12:50 PM #25Originally posted by x2pher
December 19th, 2003 03:49 PM #26
Almost all the brands function well provided to flush them at the correct intervals. Just make sure you get the right TYPE for your engine.
- Jan 2004
- 3
January 4th, 2004 02:13 AM #27I think that the the only reason that radiator coolant is colored orange(red) or green is for identification.
After you use your car, the only thing that drips from your car should be water from the aircon (assuming you use your airconditioner). The next fluid that could lead would be oil engine, transmission, which is easy to detect by our sense of sight or touch. Then it would be brake fluid, which has an odor, just like oil. You can tell the difference between oil and brake fluid/water by their color. Water and brake fluid can be identified by the texture of the fluid and the slight pungent smell of brake fluid.
Now if the radiator leaks and its filled with water, you can't tell the difference from the condensed water from your airconditioner. If coolant was not colored and dilluted at 50%/50% or 30%/70% with water, you wouldn't think that your engine cooling system had a problem until you boil over.
The colored liquid/residue that you would find under your car would tell you what sort of fluid was leaking and should give you and off hand indication of where to start looking.
January 4th, 2004 02:30 AM #28
The red coolant has a different formulation from the green one. Ipinaliwanag na ito dati (hindi ko lang mahanap). Interchanging them can lead to disastrous (and possibly expensive) results that is why they are of different colors.
I think both of them are still ethelyne glycol based.
January 4th, 2004 05:53 AM #29
one liter lang ang coolant ko used mainly for it's anti-corrosive properties lang. di naman nag oover heat even sa traffic.
- Dec 2003
- 35
January 10th, 2004 04:15 PM #30oii.daming reply.. check my radiator lately d pa naman kinalawang gamit ko ngayon is wilkins and yung red coolant since d kelangan ng antifreeze consedering sa climate..normal lang daw mag init ng konti ang sasakyan lalo nasa heavy traffic lalot sa kainitan ng araw.. dami kong natutunan tnx guysss
My Ford SYNC just updated itself. Anyone here knows what was updated?
2023 Ford Everest Owners Thread
