Results 1 to 5 of 5
    May 2005
    Can a dramatic effect be felt after using these engine cleaning additives, especially if the engine has already ran 100K+ Kms?
    Feb 2005
    Better performance, cleaner emissions, better fuel economy. Not as good as when the engine was brand new, but better than before the cleaning.
    May 2005
    If there are tangible results then... can you recommend any additives that might suit my old engine?
    Nov 2003
    hardly any of these additives work... i would spend my money somewhere else.
    assuming you perform regular change oils, your engine should still be clean even at 100k kms.
    imho. no need to add engine additives. the engine oil that we use has that component. waste of money lang sya.
    ang sagot dyan is regular oil change.
Engine Cleaning Additives?
