Bro.,- I assume that you're in 4th or 5th gear when you're running at 130KPH and you lifted your foot from the gas pedal,- that's why you were saying that you're engine braking? Is that so?
If that is the case, then that is perfectly normal, rather than engaging the 'angel gear', i.e. neutral gear, which could be fatal at that scenario.
Don't worry at your engine,- it can handle that. However, be wary of down-shifting to 2nd or 3rd gear at that speed,- it could blow up the engine...
