Results 11 to 18 of 18
January 4th, 2011 03:50 PM #11
sorry to revive this old thread. I would like to ask san meron mabibilhan ng Elf lubricants?
- Feb 2011
- 129
March 13th, 2011 05:01 PM #12meron nga dealer ng ELF motor oil dun sa tapat ng SM marilao. malapit sa Bar Ko(barko) at firestation.
I kind of forgot the name, kaso dun ako kumuha dati para sa MC namin.
March 15th, 2011 12:16 PM #14
I've inquired also at my suking auto supply.
The Elf lubricant for diesel is pegged at P700 plus for a 4-liter pack. HIndi ko na maalala yung exact name. could be that "Trophy". Blue and Black yung packaging....At that price (P700+), is it really a synthetic?
March 15th, 2011 12:58 PM #15
- Jan 2011
- 123
March 15th, 2011 02:12 PM #17Thats not a synthetic oil based on the price alone.If its not labeled a synthetic on packaging,then its a mineral oil.One thing to remember,oils that darkens easily have higher detergents.Kapag ang gamit na langis noon ay matagal umitim,mababa lang ang cleansing agents nito.Ngayon,kapag nagswitch sa high detergent oil,huhugasan nito ang mga gums sa loob ng makina at madaling magbara ang oil filter.Kapag clogged na ang oil filter,dadaan ang langis sa bypass valve at di na masasala ang langis.As a safe measure pag gumamit ng madaling umitim na langis,change oil after 1k km of use,then another 2k for the next one.Pagkatapos pwede na ang 5k mark para sa mineral oil,7k sa partly synthetic,10k sa semisyn.Iba ang procedure sa fullysyn switching,masyadong matrabaho at magastos.
March 15th, 2011 05:05 PM #18
Yup ganyan ang ginawa ko nun...Before Castrol GTX ang gamit ko. Yun nga napansin ko na matagal na umitim. Castrol CRB tinesting namin sa tractors, ganun din matagal umitim...Nung nagswitch ako sa Delo Gold, ayun withn a day umitim. First oil change was after 1k km of using Delo Gold then change oil and filter then every 5k km na ang oil change tapos 10k change ang palit ko ng filter.....for 3 years na na Delo Gold ang gamit ko.
I've read also from some reading na dinadaan lang sa marketing strategy ang Castrol but actually mahinang klase mga langis nila.
high idle RPM at engine start
