Results 11 to 12 of 12
August 16th, 2009 09:49 AM #11
Simple.
You can use a mobile phone to receive the signal to enable or disable the car. The mobile phone will trigger a set of relays to close/open to enable/disable certain key components in the car.
Those key components would depend on the vehicle but would include:
-electric fuel pump
-ignition switch
-onboard alarm system (siren, lights, etc)
August 16th, 2009 10:01 AM #12
Just use an aftermarket alarm and modify it to receive commands from a cellphone (instead of its transmitter only) if what you want to be able to command the vehicle.
An aftermarket alarm already has leads to disable the engine, lock/unlock doors, flash the lights, trigger the siren, etc.
You can add , The Ten Commandments, BenHur ....
Traffic!
