Results 1 to 12 of 12
    Jan 2008
    dude try upgrading first your engine or you might end up blowing it...
    ECU programming is tricky you must have skills for that...
    pass the stage 1&2 first before tricking you ECU
    there are times that not only the engine will be fried but you wiring harness as well
    Aug 2004
    Btw, nerds... what engine and what mods do you have?
    Aug 2009
    mga sir my project kasi kami bout sa gps tracking ng kotse. pano yan nilagay nmin don ikakabit ung device sa ecu ng kotse(honda 1998 ed sir ata) tpos my capabilities syang idisable ung makina. so ecu po tlg kami coconnect nito advisable po ba yan? or is there anyway na madisable ung makina ng hnd ka dadaan sa ecu??
    pwede yan sa main relay at ignition switch .
    main relay cuts off fuel pump
    ignition switch cuts off ignition power to all of the fuel,spark,and ecu.
    within minutes na may breach of security the engine will shut off.
    pwede mo na rin i super lock yung doorlock systems ,it's your choice
    para hindi makalabas yung mga bad guys.
    Quote Originally Posted by kelvinblank View Post
    [SIZE="4"]REMINDER: do not post in SMS/TXT format when posting in tsikot.com[/SIZE]
    Simple.
    You can use a mobile phone to receive the signal to enable or disable the car. The mobile phone will trigger a set of relays to close/open to enable/disable certain key components in the car.
    Those key components would depend on the vehicle but would include:
    -electric fuel pump
    -ignition switch
    -onboard alarm system (siren, lights, etc)
    Just use an aftermarket alarm and modify it to receive commands from a cellphone (instead of its transmitter only) if what you want to be able to command the vehicle.
    An aftermarket alarm already has leads to disable the engine, lock/unlock doors, flash the lights, trigger the siren, etc.
ECU programmable
