Page 2 of 2 FirstFirst 12
Results 21 to 29 of 29
    #21
    i would replace my belt, when it shows minute cracks on the ridged inner surface. kuripot ako.
    others would replace theirs, after every xxxx km, regardless of belt condition. pms to the fullest definition! heh heh.
    Jul 2014
    #22
    Thank you guys for the inputs. Papasadahan ko nalang for the next PMS if due for replacement na talaga. More power tsikot!!
    Apr 2005
    #23
    Napansin ko yung drive belt Altis ko parang may tahi sa outer part. Tapos ngaun parang lumalalim na yung tahi. is that a sign to replace?
    #24
    From the 4runner forums: Replacement OEM Serpentine Belt fraying?! | Toyota 4Runner Forum
    I contacted Bando for a definitive answer. They’re the ones producing these made in the USA OEM belts for Toyota.
    Here’s the engineer’s response:
    “That fraying will eventually wear off. The fabric is only stitched to hold it in place during the building of the belt. The rubber impregnated fabric is cured to the backing of the belt so the stitching isn’t relevant to the functioning of the belt during use.
    Most auto manufacturer’s have transitioned to a rubber backed belt without any fabric backing. As I mentioned on the phone, our aftermarket belts do not have the fabric backing.”
    I bought a second belt from Toyota and it’s obvious the same stitching will have similar results. Glad there’s nothing to worry about.
    Hopefully this might help someone else.
    So seeing the stitching apparently means your belt is still fresh since it hasn't been thrown off yet.
    #25
    i pay attention to the cracks that might appear on the inside, perpendicular to the long axis.
    the other week, i had the altis belt replaced.
    it didn't have many cracks, but it had been making squeaking noise when started from cold in the morning.
    i googled and saw the squirt-water test.
    ok na si new belt. tahimik na ulit.
    Feb 2009
    #26
    One of the indicators of a premature worn serpentine belt is the sign of the pulley groove crest that is polished and the groove valley of the belt being in contact with the pulley crest. The belt was designed to have contact with the inclined surfaces of the belt and the pulley. Also check for debris stuck in the pulley grooves.
    When changing your ride's serpentine belt, is it a must to replace the tensioner too?
    #28
    i don't.
    and after several years, the tensioner still hasn't shown signs of wear.
    Jan 2009
    #29
    IMO, it's not required as long as it's not making any fuss.... no bearing noises, excessive play, and especially if the pulley wheel condition is still good, etc... it can stay. If the pulley wheel is worn down and has ridges, it might eat up the new belt. Otherwise, they are pretty much accessible and can be replaced at any time.
    It's when replacing the timing belt or timing chain is when you should replace many of the other timing components... guides, tensioner, sprockets, and sometimes including the water pump if it's in there and/or driven by the timing belt or chain.
Drive belt engine
