Page 7 of 8 FirstFirst ... 345678 LastLast
Results 61 to 70 of 73
    congratulations, travs!
    you have a convert!
    best wishes to you, too, yaps.
    kakulto!
    Jan 2008
    #62
    Quote Originally Posted by chronicle View Post
    So tama ba 2.5k nga? Based sa fb search.
    Or cheaper?
    2.2k lang paps..
    I do my oil change so mag benefit ako sa fumoto.. 2.2k well spent.. kesa burloloy bilhin ko.. hehe
    #63
    you have a convert!
    Haha, that should be deflected towards the deserving product, doc. Just a sharer of discoveries.
    kakulto!
    No Apollo nor flock here, brother Stock.[emoji13]
    #64
    Installed the fumoto valve.. nice fit to my 4d56 engine!
    The package comes with a fumoto clip and the seller included the plastic nipple with hose extender..
    The valve does not protrude.. just like the old drain plug.. its just longer by 10mm and in no way can be hit by rocks underneath..
    Nice! Price & Fumoto model for 4D56, sir? Thanks!
    Haha, that should be deflected towards the deserving product, doc. Just a sharer of discoveries.No Apollo nor flock here, brother Stock.[emoji13]
    cheers to yacult🍺🍺
    Jan 2008
    #66
    2.2k for the fumoto F106S.. comes with the clip.
    The sx model for recessed drain plug port is priced at 2.4k
    Oct 2003
    #67
    Meron ba for Honda L13A engine?
    #68
    Thanks. Pricier than Amazon, but still affordable. F106 is probably the most common.
    Quote Originally Posted by zechs View Post
    Cross reference your car/model/year here, sir:
    Fumoto(R) USA | Quick and Easy Engine Oil Drain Valves
    #69
    perfect ang fumoto sa 1st gen fortuners. yung engine oil drain plug is located immediately behind and recessed sa front suspension crossmember
    so bago sya tamaan ng extraordinarily large road obstruction malamang matanggal muna yun dalawang gulong hehe.
    also as an added benefit kapag change oil time di na kakalat yun tulo ng langis sa crossmember
    Nov 2014
    #70
    Hindi natatnggal yung washer ng drain plug ng Ertiga, not sure kung across all model yon.
    Hindi ko din matandaan kung napalitan nung previuos PMS sa casa nung naka warranty pa.
    Pero at least Dec 2018 til kanina na DIY same washer pa din, nilagtan ko lang ng mighty gasket by Pioneer gasket maker yung last 2 OC ko
    Order na rin lang ako sa casa or lazada next oil change, pero lagi ko naman minomonitor for leakage
    Sent from my LG-M700 using Tapatalk
Does drain plug washer is really required to replace every oil change?
