Yeah you're right about the radiator cap being relative to ambient, but IIRC the boiling point elevation you get from a 1 bar radiator cap plus a 50-50 coolant mix is high enough that the change in elevation shouldn't matter.
Metro manila is currently 1006hPa, Baguio at 853hPa. Boiling point will be just under 100C here, 96C in Baguio -- 4% decrease.
A 1 bar radiator cap raises boiling point to 268F (130C). Applying the same 4% loss (since the percentage pressure delta will be similar) = 124.8C. I don't think a car will be seeing 120+ coolant temps even in Baguio.
AFAIK one of the reasons behind pressurized cooling systems is so that modern cars can perform at altitude -- yes the boiling point is lower, but the cooling system is overdesigned and should handle it (provided of course that it's properly maintained).
