Tank is almost half empty after i tried adding 2T a month ago. No noticeable difference after adding 2T engine sound, vibration and acceleration is still the same. Will observe in the months to come.
Posted via Tsikot Mobile App
ano effect nito sa 2002 Nissan patrol zd30 engine? what is the correct mixture 200ml:40L?
Sir Retz ano vehicle mo? i have the same problem fuel gauge.. ok n po b yung sayo? what did you do to fix?
Ung sa innova sir mukhang hindi pa rin okay fuel gauge. Pero once pa lang ako naglagay 2T. sayo sir ?
Hi guys, this is my first post here in tsikot.. So as I have read all the things I need to know in adding 2t oil on diesel fuel, I decided to give it a shot on our d4d engine, so far all are positive effects.. I just wanted to know since doc said that it is not necessary to put on R-eVGT engines since they have higher common rail pressure compared to others.. What would be the effect if I try putting in 200:1 ratio of 2t oil on an revgt engine? I also saw in one post that someone has tried it on his santa fe r-evgt engine.. Will it still work like on any other old school diesel? Thanks tsikoters and hoping to hear from the guy who tried it on their SF3..
Is the pressure reading for your R-evgt engine greater than 1800bar sir?
Yung Tucson R-evgt ng friend ko ginagamitan ng 2T. Ok naman no issues.
Hi sir, regarding the pressure of the common rail, i haven't tried measuring it. Hindi ba parehas lang naman lahat for all Hyundai R-eVGT engines?
ni check ko ung pressure ng r-evgt engine sakto nasa 1800bar sir. so nasa borderline..... ang hindi pwede ung mga german cars that have extremely high crdi pressure nasa 29k psi na mga un.
Sa fortuner ba sir ano naramdaman mong difference after adding 2T?
The shutoff shudder and the smoothness of the engine.. Almost as if you are running a gas engine..
I've never tried this one before, and am considering it for the Revo diesel. Is this available in all gas stations? How much does it cost?
Sent from my GT-I9100 using Tapatalk 2
Yes, it is available in gas stations. It cost Php25 per 200ml bottle.
