Page 13 of 48 FirstFirst ... 39101112131415161723 ... LastLast
Results 241 to 260 of 1853
    Quote Originally Posted by stevilla View Post
    Any idea sir kung ilang bar psi ang crdi system ng accent?
    Not more than 1,500 pa sir so puwede.
    Fuel is supplied ..... from a cylindrical tube which is pressurized at about 1400 bars and fuel is injected at a pressure of 1350bar as compared to the 400-odd bars at which the fuel is injected in normal diesel engines.
    Feb 2012
    mga sir may expiration date ba ang 2t oil?
    Quote Originally Posted by trucker111 View Post
    Unioil now offers Eurodiesel IV which is Euro IV compliant diesel. do we still need to add 2T to this diesel fuel?
    Sir, back read a little bit and you'll find your answer.
    Sep 2004
    If you have a old school diesel you should avoid using Euro IV spec fuel is 50ppm sulfur, Which is 450ppm less than the standard diesel available there, it's really backwards thinking to even sell that considering less than 1% of the engine there will run properly with it. You put that in a older diesel it's going to shake like it's full of rocks.
    Adding 2T to Euro IV fuel will still be less than 500ppm so it's just a waist of time and money to use it. It will shorten the life of your injection pump greatly on most vehicle in the Philippines.
    Is total's low sulfur diesel plus total 2t going to ruin a 4m41 injection pump?
    Sent from my iPad using Tapatalk HD
    Amen!!!
    One last would you know how the specs of the new 2.2li Ford Ranger engine? I wonder if it has too high a pressure to use 2t
    Sent from my GT-I9100 using Tapatalk 2
    Apr 2008
    Hi im about to buy my first 2T oil na ihahalo sa alterra ko. After reading the thread ok you PTT dahil FC rating,but would be an overkill kasi pwede na ung FB rated lang tska malayo ata ang bilihan mula sakin (mandaluyong) o meron ba sa handyman/ace/blade nito. Sa petron or shell 2T any specific type ang dapat ko pong bilhin/hindu dapat bilhin po? Tska ano un iiwasang type ng 2T?thanks!
    Nov 2004
    Nakaka adik pala tong 2T... Once you pop you cant stop! :D
    Pag nasanay ka na manakbo makina with 2T parang ang gaspang na pag w/o 2T. Smooth talaga mala gasoline type pati acceleration pag naka 2T ang diesel! Hehe.
    Quote Originally Posted by halimaw View Post
    Tsaka ramdam mo talaga na much better FC with 2t oil.
    - - - Updated - - -
    Aug 2008
    Quote Originally Posted by bors View Post
    Ano ang effect ng 2t sa gas engine?
    Carb fed ba or fuel injected?
    I use 2t in our 04 civic, engine runs smoother and does not have any adverse effects. My ratio though is 1% for every liter. Afaik, there is no effect when you use it in a carb engine.
    Quote Originally Posted by rac98 View Post
    can you use 2t oil for gasoline engines? anybody else tried this? wanna try for my beat up civic 99. so far our starex 2006 Grx is doing well with Total 2T.
    Quote Originally Posted by poorprince View Post
    It's for diesel engines only.
    Never mind, found the ratio, thanks anyway.
    - - - Updated - - -
    Apr 2008
    Hi im about to buy my first 2T oil na ihahalo sa alterra ko. After reading the thread ok you PTT dahil FC rating,but would be an overkill kasi pwede na ung FB rated lang tska malayo ata ang bilihan mula sakin (mandaluyong) o meron ba sa handyman/ace/blade nito. Sa petron or shell 2T any specific type ang dapat ko pong bilhin/hindi dapat bilhin po? Tska ano un iiwasang type ng 2T?thanks!
    Aug 2008
    Quote Originally Posted by MR_MAHAROT View Post
    Any 2t will do, just make sure it is fb or fc rated and do not buy synthetic ones. From my experience, PTT gave the best result, followed by shell, caltex, then petron. Those are the only brands i have tried so far.
    Dec 2007
    You can use it a gas engine ratio is different
    Aug 2008
    I'm doing it with our civic which is a gas fed. With different ratio though, as doc said..
    Feb 2012
    Hi. newbie here. I have 2012 montero sports vgt glsv. Is it safe to load up 2T? And also just owned a 2.2L mazda bt50 2013 model and want to know if 2T is applicable on its engine. The crdi of mazda states this = Both 2.2L and 3.2L powerplants feature a cast-iron cylinder block with ladder frame construction for greater rigidity, an aluminum cylinder head, maintenance-free chain-driven camshafts, and maintenance-free hydraulic lash adjusters. An advanced ultra-high pressure (1,800 bar) common-rail injector system with precision multi-stage piezo injectors is fitted to all diesel engine variants, with a variable-nozzle turbocharger on the 3.2L and 2.2L units. TIA
    Feb 2012
    Newbie here. I owned a 2012 Montero sports VGT glsv model. Is it ok to use 2T in it? I also owned 2013 2.2L mazda bt-50 and the engine crdi specs shows this - Both 2.2L and 3.2L powerplants feature a cast-iron cylinder block with ladder frame construction for greater rigidity, an aluminum cylinder head, maintenance-free chain-driven camshafts, and maintenance-free hydraulic lash adjusters. An advanced ultra-high pressure (1,800 bar) common-rail injector system with precision multi-stage piezo injectors is fitted to all diesel engine variants, with a variable-nozzle turbocharger on the 3.2L and 2.2L units. Is it still ok to add 2T in it? TIA
    Feb 2012
    * dvldoc and rac98, what ratio for gas engines? And how does it help with gas engines? I'm using it on my diesel ride, but I also have a gas engined ride. Might give it a try if it has the same benefits.
    - - - Updated - - -
Diesel owners that add 2T oil to fuel
