Page 3 of 5 FirstFirst 12345 LastLast
Results 41 to 60 of 85
    #41
    Quote Originally Posted by Kimchijiji View Post
    Pwede ba na kahit nagkarga ako ng 5liters diesel sa 1/4 tank, eh wala akong mararamdaman? Posible ba yun?
    Hindi. You would've felt it immediately.
    Again, Occam's Razor. The simplest explanation is that you were loaded with gasoline, but with a black nozzle jacket. Which is why there is no detrimental effect to your car.
    In my years of petroleum experience, gas boys rarely misfill sedans because they assume they're gas-fed by default.
    Jan 2017
    #42
    If i would felt it immediately, matagal ba ung effect? Or like pde 5seconds ln or maybe 10 and thats it? Btw my car is mazda3 hb not a sedan
    #43
    Doesn't matter if it's a hatch or sedan, it's not an SUV/MPV/van so it's unlikely that they will mistake it for a diesel.
    You would feel it immediately and the effect will linger until you flush out your fuel and clean your fuel lines.
    Jan 2017
    #44
    Ohhh so its unlikely na nalgyan nga ako ng diesel. Ung nahrpan ako nung night na un cguro dahil sa heavy rain. And that morning wla nmn nako naramdaman until today. So if i really have put diesel pn my car, dpat nag iistall padin sya ngayon am i right?
    Pero what if dahil 150 lng pinagas ko, they might think na diesel ipalagay ko kasi dahil sa urban myth "konting diesel helps a petrol engine"
    #45
    Yes.
    No. None of my gas boys have ever assumed that.
    In fact, it isn't even a widespread myth (and it's an erroneous one at that).
    There are only 2 real things you can do - 1) accept that you weren't misfilled and carry on with your life, or 2) drain your fuel now if you're so sure you have diesel in your tank.
    Worrying endlessly on the forums despite everyone saying it's a long shot that you got misfilled isn't really a productive option. But hey, if it makes you feel better, go ahead.
    Jan 2017
    #46
    Yes.
    Thanks for replying and helping me alot. Maybe i really did not have put diesel on it. modern cars should be more sensitive to misfuel and the fact that i did not notice anything different must be i did put on unleaded
    Aug 2017
    #47
    Use FLYING V's diesel. Very economical and good for engine. Just using this petrol brand for almost 6 years and still my Mitsubishi lancer 2011 is in good shape.
    Jan 2017
    #48
    To be sure, may mga shops ba na pdeng icheck(not drain) pra makita kng contaminated nga ung fuel?
    Jun 2012
    #49
    Makulit si kimchi. Sinabi nang hindi yan nagkamali, eto naman so lemwellc panay ang ads sa flying V. Kada post puro flying V sinasabi
    Sent from my HM 1S using Tapatalk
    Feb 2014
    #50
    drain mo nalang tank mo para magka peace of mind ka...
    pero most probably hindi nakargahan ng diesel oto mo.
    Aug 2013
    #51
    pwede mo DIY sir.
    check mo lang spark plugs. clean burning ang mga modern mazda engines, dapat more of light gray to light brown color (very lean ang mga mazda, lalo na kung sky active)
    kapag maitim at oily yung spark plugs, plus kapag nag rev ka palyado (hindi kasi nasusunog ng spark plugs ang diesel), malamang nakargahan ka nga ng diesel.
    tama sabi ni sir Jut, kapag nalagyan ka ng diesel, ramdam agad.
    isa pang way kapag hinawakan mo yung fuel mismo, dapat malamig, kapag hindi, nahaluan ka ng diesel.
    madalas kasi ito mangyari sa taxi namin, mga 3 times na nangyari, ok pa naman fuel delivery niya, hinahaluan ko na lang ng STP injector cleaner.
    Jan 2017
    #52
    Quote Originally Posted by innova2013 View Post
    pwede mo DIY sir.
    Cge sir check ko tas update ko po
    Jul 2006
    #53
    Quote Originally Posted by Lemwellc View Post
    Kamusta naman ang Peugeot mo?
    Ok pa rin ba?
    Jan 2017
    #54
    Btw sir lagi kong nirerev hnd nmn pumapalya
    May 2011
    #55
    The contaminated fuel will have been spent by now if indeed it had been misfueled. This is just about getting old. Maybe next time you will not repeat the same error.
    Jan 2017
    #56
    Quote Originally Posted by mina_nuka View Post
    Usually the contaminated fuel and poor performance should still be there until it is flush out right? So if there is no irregularities and run like before, hnd ako nakargahan ng diesel?
    Btw i was planning on going to rapide for free checkup. Should i or should i not?
    Apr 2012
    #57
    Kung rapide lang wag na [emoji23]
    Isipin mo na lang di nagkamali. End of story. Pag dinala mo sa rapide yan, malamang new thread will be started by you [emoji16][emoji23]
    Sent from my LG-H818 using Tapatalk
    #58
    All signs point to non contamination. However, if you really want to have it checked. Choose another car shop.
    Jan 2017
    #59
    What shop would you recommend?
    May 2011
    #60
    Bury the notion. Your car is fine.
Diesel loaded in a gas engine
