Results 1 to 10 of 2348
    May 2004
    Good day sir dieseldude !!!
    Whenever i start up my hilander 97 model for the first time, i notice a pool of diesel forms under the engine. Spill size is about a small coffee cup. The engine also shakes violently at times during the first start. What could be the cause of these?
    TIA
    Sep 2006
    Quote Originally Posted by boy astig View Post
    TIA
    You have a fuel leak which only you can locate.
    Wipe the injection pump and pipings clean, start the engine, and locate the source of the leak.
    May 2008
    go central diesel! that injector retime did just the thing! solved my hard start and white smoke problem :0 all i have to do i check the mileage i do now
    May 2010
    kagaya po ng regular VE type injection pump. papaano po inaadvance at dinedelay ang CRDi?
    Quote Originally Posted by muŅoz View Post
    ang timing control ng CRDi pumps ay hindi na mechanical tulad ng mga traditional VE pumps. Nag d-drive lang ng high pressure fuel ang supply pump to the rail to the injectors.
    Ngayon, depende sa camshaft and crankshaft sensor with respect to load, iniiba ng ECU ang triggering ng injection ng injectors; Hindi na pump ang nagcocontrol nyan kundi ang Engine ECU and Transmission ECU sabay-sabay.
    Apr 2009
    hi dieseldude ..
    thank you for sharing your knowledge and experience, I learned so much from this forum.
    I have a question. I read from an article that mixing diesel and auto transmission fluid is good for the injection pump. is this true? and mixing
    it with motor oil on oil change?
    Sep 2006
    Quote Originally Posted by anthon05 View Post
    hi dieseldude ..
    I have a question. I read from an article that mixing diesel and auto transmission fluid is good for the injection pump. is this true? and mixing it with motor oil on oil change?
    I have also hear about this. However, I have not seen technical or service information from any diesel injection pump manufacturer which approves of this practice.
    I wouldn't do it.
Diesel Fuel Injection System Help Desk
