Results 1 to 6 of 6
- Feb 2003
- 9
February 20th, 2003 08:53 PM #1Magandang araw po ulit. Napansin ko pong mayroong bagong Shell Helix Diesel Super oil. Sabi sa sa commercial ay mayroon po itong vibralite additive that removes vibrations and makes the engine running smooth.
Mayroon po akong L300 '93 diesel na medyo makalog na makina. Pag ito po ba ang oil na ginamit ko ay mawawala na ang kalog? Tatahimik din po ba makina ko?
Salamat po.
February 20th, 2003 09:24 PM #2
Kadalasan pag bagong palit ang oil pino o smooth ang takbo ng diesel or gasoline for that matter. I think a much better way is to check your engine and xmission mounts. Also install an inline anti-vibration thing (don't know the exact term) between the exhaust manifold and the resonator.
February 20th, 2003 10:01 PM #3
at marami pa pong ibang paraan (na hindi ko na alam) kung paano MABAWASAN (and not MATANGGAL) ang mga vibrations..hindi lang sa oil....meron pang mounting....supports..etc....
February 20th, 2003 10:23 PM #4
pa balance mo ang propeller, balance ang crankshaft but a little vibration won't hurt that much as against the cost of balancing engine and drivetrain conponents.pa balance mo ang propeller, balance ang crankshaft but a little vibration won't hurt that much as against the cost of balancing engine and drivetrain conponents.
BANNED BANNED BANNED
- 3,790
February 20th, 2003 10:53 PM #5Originally Posted by afrasay
February 21st, 2003 08:43 AM #6
Machine shops usually do this balancing. Mas maganda kung sa medyo malaki na shop ka magpagawa para siguradong may lathe machine nakaya ang ganun kahabang propeller. One shop I know is in Roces Ave. Q.C., Precision Automotive. Meron silang Dynamic balancing, engine stress reliever, and etc.
high idle RPM at engine start
