Results 21 to 28 of 28
April 12th, 2008 12:15 PM #21
Tanong lang po, yong crosswind exhaust fitted ba ng catalytic converter. 2005 yong crosswind ko. sa diesel expert po, i appreciate your answers.
May 7th, 2008 06:59 PM #22
August 17th, 2010 04:47 PM #23
No, it will not damage but make sure you need to dry it in case water entered. Catalytic converters are used in internal combustion engines to reduce harmful carbon monoxide emissions. They also break down nitrogen oxides to nitrogen and oxygen and hydrocarbons into water and carbon dioxide. Catalytic converters accomplish these tasks by causing chemical reactions with the exhaust emissions as they flow through. The catalyst used most often in converters are platinum, rhodium or palladium, as these are very reactive metals. The core of the converter is often ceramic or stainless steel. They are formed like a honeycomb to increase the surface area, which increases the effectiveness of the catalyst. Many problems can arise with catalytic converters, which can affect how the engine runs.
August 20th, 2012 06:04 PM #24
mga paps pede ba ang ilagay sa loob ng muffler e sosa? ung pantanggal ng bara sa lababo
August 27th, 2012 10:03 PM #25
Certified MB Addict
- Apr 2007
- 2,284
August 27th, 2012 10:25 PM #26
August 27th, 2012 10:40 PM #27
Shame they could have went with the fortuner V(that is not mentioned in brochures at all) route of...
All New Toyota Corolla Cross
