Results 1 to 20 of 28
    Sep 2005
    When I was doing carbon flushing di tubig and detergents ang ginagamit ko. May mga chemical talaga para diyan. Beltran used to do carbon cleaning pero ngayon wala na, shucks. Ang alam ko the gas stations sa may T.Morato intersection nag carbon flushing. Sa mga new CRDi engines alam ko walang butas para pwede idaan yung liquid solution kaya ang ginagawa nila is that they drill a hole doon sa downpipe.
    Sep 2006
    Smoke is generated by the engine, not the exhaust system. Cleaning the exhaust system with water will not cure the problem of excessive black smoke from a faulty engine or injection pump.
    Light soot build up in the exhaust system is normal. The exhaust system cleans itself out through normal driving and occassional hard accelerations.
    Heavy soot build up is not normal.
    Apr 2006
    what's the real deal about this?
    pag maitim na ang usok na nilalabas what else could be done?
    thanks
    Sep 2006
    Quote Originally Posted by jundogg View Post
    thanks
    Check your engine's air filter and/or injection pump.
    Jan 2008
    thanks
    sir pacheck na ninyo yung infection pump, injector nozzles ninyo...
    Jan 2008
    thanks
    sir pacheck na ninyo yung injection pump, injector nozzles ninyo...
    Sep 2005
    Tanong lang po, yong crosswind exhaust fitted ba ng catalytic converter. 2005 yong crosswind ko. sa diesel expert po, i appreciate your answers.
Diesel Engine: How to cleaning the exhaust system?
