Results 1 to 7 of 7
    Jun 2017
    pa help naman mga sir.. yung 4k carb ko ayaw mag idle kailangan taasan idle/rpm nya para di mamatay kaya lakas kumain ng gas.. nilinis ko na carb ganun padin/// nag try din ako palit mga jetting gasket etc. na kasama sa repair kit no luck padin.. check ko mga vacuum hose with carb cleaner wala naman leak... change spark plugs still no luck.. check timing,, clean distributor cup. ayaw talaga.. pa tulong naman mga sir
    thnx in advance po...
    Quote Originally Posted by odraregnivla View Post
    The carb may be old, but it is still a complex piece of part. Check the floater, pag mali timpla nito, pwede malunod yung carb kaya namamatay pag mahina ang idle, happened to me before. If in doubt, better have it checked by a carb technician/specialist.
    Aug 2017
    Pagawa mo sa A&M sa Kamuning QC.
    I can overhaul an engine, Carburetors hindi ko kaya, ibang animal yan.
    May 2011
    Alvin
    First of all, carburetors sit at idle on a table.
    Maybe you mean a carburetor engine does not run normally at idle.
    You have done stuff that did not address the problem. Did you do a running engine intake manifold vacuum reading? A normally aspirated engine with OEM camshaft should run between 17 to Wq inches of Mercury vacuum being 21 the preferred. If the vacuum reading is low you might have a vacuum leak, bad PCV valve, late ignition timing or late valve timing. This is very basic if your mechanic or technician knows what he is doing.
    Jul 2019
    Its the solenoid. Everything you described points to that. either na putol un kuryente theres a wire connected to your carb or sira ang solenoid. madali lang yan palitan sir. You should carry a spare with you also.
    Gaano kataas ang idle (rpm) para hindi siya mamatay? I assume this is with aircon and headlights,
    Sep 2019
    bumping this thread and following,
    I am also having somewhat the same issue, new 4k carb has no-idling according to mekaniko
4k carb ayaw mag idle
