Results 1 to 7 of 7
- Jun 2017
- 12
June 25th, 2019 09:04 AM #1pa help naman mga sir.. yung 4k carb ko ayaw mag idle kailangan taasan idle/rpm nya para di mamatay kaya lakas kumain ng gas.. nilinis ko na carb ganun padin/// nag try din ako palit mga jetting gasket etc. na kasama sa repair kit no luck padin.. check ko mga vacuum hose with carb cleaner wala naman leak... change spark plugs still no luck.. check timing,, clean distributor cup. ayaw talaga.. pa tulong naman mga sir
thnx in advance po...
- Nov 2008
- 641
June 25th, 2019 10:02 AM #2
- Aug 2017
- 319
June 26th, 2019 10:01 AM #3
- May 2011
- 481
June 26th, 2019 10:38 AM #4Alvin
First of all, carburetors sit at idle on a table.
Maybe you mean a carburetor engine does not run normally at idle.
You have done stuff that did not address the problem. Did you do a running engine intake manifold vacuum reading? A normally aspirated engine with OEM camshaft should run between 17 to Wq inches of Mercury vacuum being 21 the preferred. If the vacuum reading is low you might have a vacuum leak, bad PCV valve, late ignition timing or late valve timing. This is very basic if your mechanic or technician knows what he is doing.
- Jul 2019
- 10
July 2nd, 2019 02:36 PM #5
July 2nd, 2019 05:06 PM #6
- Sep 2019
- 8
September 2nd, 2019 08:44 PM #7bumping this thread and following,
I am also having somewhat the same issue, new 4k carb has no-idling according to mekaniko
IIRC they're with AVID. The reported numbers in the TG article are from CAMPI.
Car Sales Data (2024)
