Page 1 of 3 123 LastLast
Results 1 to 10 of 21
    Jan 2013
    Hello mga Paps and Mams,
    Is it bad to use Cruise during break-in period? Because you will have a constant RPM. Hindi naman maiiwasan sa Hi-way ang constant rpm, maliban nalang sa zigzag roads.
    And I think sa factory palang binirit na yung engine.
    Thanks.
    completely fine.
    Break-in rule of thumb...
    cruise control isn't slow.. 40kph-100kph will be at the mid rpm. It'll be fine
    Just not at extended constant speed. It's just 1k kms worth of wait.[emoji4]
    Jan 2013
    Used it in NLEX at 100kph which is fast
    Kahit naman kasi di gumamit ng cruise, constant talaga speed at rpm sa nlex hehe
    Quote Originally Posted by kris_13 View Post
    100kph is around 2000rpm(plus or minus 250rpm depeding on vehicle) its the sweetspot for most engines. thermal efficieny is near the peak.
    120 is fast as it is away from the peak thermal efficiency...this should be avoided during break-in
    May 2019
    Don’t overthink it. Just drive normally and not like “drive it like you stole it” type.
    Congrats and drive it in good health.
    Jan 2013
    Quote Originally Posted by Wave24/7 View Post
    Yes Sir, I just drive it the normal use. I asked this bec someone mentioned that it should be avoided haha.
    In the first place, the manufacturers should have disabled cruise until you reach a thousand mile to enable cruise if it will destroy the engine.
    I am new to AT cars, always drive a manual for many years. thanks
    May 2019
    You’ll likely damage the engine through overheating and not following proper oci.
Cruise control during break-in period
