Results 11 to 14 of 14
December 19th, 2008 02:32 AM #11
TUBIG AT LANGIS ay completely diff.
OIL SENSOR; are mounted on the side of the block. Most of it are on the passenger side of the engine itself about halfway between the exhaust manifold and the top of the oil pan.
COOLANT TEMP. SENSOR; it is located on upper engine area mounted top driver side of engine.
- May 2008
- 33
December 19th, 2008 05:20 PM #12Thanks sa reply natuto ako dun ah .....so bakit po kaya nawala yng ilaw ng oil indicator panel? thanks po ulet sa pangungulet ....
December 20th, 2008 03:58 AM #13
Again, oil sensor and coolant are totally different. Your oil sensor has nothing to do w/ water. If the oil lights indicator appear while driving its possible that your oil pump is getting weak and not pumping up enough oil to the top end of the motor and is getting ready to fail.
Maswerte ka nga at hindi pa nagpaparamdam sa iyo. When that time come's, kiss and say goodbye sa wallet mo.
- May 2008
- 33
Xiaomi E-Car
