Results 21 to 30 of 33
Tsikot Member Rank 5
- Nov 2003
- 3,848
May 18th, 2006 10:43 AM #22
my CEL is also lit, discovered a loose fuel cap but still waiting for the CEL to turn off aarrgggghhhhh
- Dec 2002
- 2,335
May 18th, 2006 11:07 AM #23Originally Posted by BlueBimmer
- Nov 2003
- 3,848
May 19th, 2006 12:04 PM #25that doesn't work for bimmers imo. you really need a reset tool to do that.
bluebimmer, if you want pass by the shop and we'll see what we can do about your service/cel light
May 20th, 2006 10:42 AM #26
To Mr. speedyfix:
At last. May obdII scanner na kayo. Is it a LAUNCH computer?
How much do you charge for it?
Does it have an adaptor for a GM car such as my Zafira? My check light lights up every once in a while but eventually turns off. If ever something really goes wrong, I want to know if you can help me... Thanks..
May 20th, 2006 11:06 AM #27
same goes to me...
starting the engine is normal...but when im driving...maybe a 3kms and more. the check engine will lights on?? do you know whats wrong?
my speedometer is not moving? is it related? does speedometer have fuse? (if, yes where??)
thanx
- Nov 2003
- 3,848
May 20th, 2006 11:16 AM #28edl, yup it's a launch. normally we check muna what the problem is then depending on what is done that's when we say what the charge will be. if it's just a reset that's needed then di ganun kamahal
kabuke0, replace your speed sensor. it's throwing a CEL code kaya umiilaw yung cel mo.
May 20th, 2006 11:33 AM #29
Originally Posted by speedyfix
LAUNCH X431. Touch screen with built-in printer. One of the best OBDII on the market. Expert na ako sa launch since my W210 always uses it.
- Nov 2003
- 3,848
I agree. travelling by train is always the fastest way to travel. kami din dati sa Bangkok, we...
Makati Subway. Completion date: 2025
