Results 11 to 20 of 33
October 11th, 2005 11:50 PM #11
Speedyfix, napaayos na ng friend ko car niya. Pero at least alam ko nang meron ka na ring obd2 scanner at least mairerefer ko na sa iyo mga ibang kaibigan ko kung magkaproblema sasakyan nila.
Tsikot Member Rank 5
- Nov 2003
- 3,849
Nagtatanim ng kamote
- Jun 2005
- 787
February 28th, 2006 01:16 PM #13Originally Posted by falken
FrankDrebin Guest
- Nov 2003
- 3,849
February 28th, 2006 10:52 PM #15oil level will have nothing to do with the cel. the oil lamp light should be the one to turn on.
just finished with a range rover kanina. cel din pero all it needed was to get cleared
BANNED BANNED BANNED
- Jul 2003
- 2,267
May 15th, 2006 10:52 AM #16paano kung sobrang tagal naman mawala yung check engine light before ma start yung engine. the car is civic esi and usually pag turn on ng key iilaw yung CEL then mawawala after a few seconds then pwede na start yung kotse. but now ang tagal bago mamamatay yung CEL. mga 15 mins before we can start the engine. pero pag nastart na, ndi na iilaw yung CEL. comments pls.!!! tnx!!!
- Nov 2003
- 3,849
May 15th, 2006 09:36 PM #17check mo muna if there is an error code or not. decode the blinks and let us know.
May 15th, 2006 09:58 PM #18
lihis ko nang konti. tutal CEL ang topic, napansin ko lang sa 96 Civic LXi namin, before ko i-start may ugong parang electrical ground habang naka-ilaw yung CEL then, clunk, patay na yung indicator then pwede na i-start. normal ba yun?
- Nov 2003
- 3,849
May 16th, 2006 10:51 AM #19if it's from behind then baka you can hear the fuel pump. if it's from under you then baka main relay.
May 16th, 2006 11:34 AM #20Originally Posted by fourtheboys96
Check your fuel filters. Yung metal canister filter sa engine bay and the filter inside the fule tank. Hope this helps
Xiaomi E-Car
