Results 1 to 10 of 33
October 7th, 2005 03:22 PM #1
Guys, could you recommend a repair shop other than Casa that could read the ECU? My friend's check engine light is always on and he doesn't want a mechanic that would resort to Trial and Error method. Thanks.
October 7th, 2005 03:37 PM #2
pag CEL wala kang choice but to go to a shop that has the appropriate diagnosis tool.
October 7th, 2005 04:14 PM #3
Correct me if I'm wrong, pero diba the
CEL comes on in 2 ways?
If it's steady , maybe your friend only needs to check the fuel
filler cap.Just tighten it and the light should turn off after
a few driving trips (nangyari na kase sa kin twice)
If it's blinking naman,that's the time to take it to a shop.Last edited by tinky; October 7th, 2005 at 04:24 PM.
01 EX Ody
- 437
October 8th, 2005 09:27 PM #5have his car scanned by an OBDII scanner to get the codes and try to research what the codes meant. Depending on the car, it may have to hook up with and OBDI or OBDII which a RS232 connector can be found under the steering wheel.
October 9th, 2005 03:20 PM #7
Kung civic yan I can teach you how to get the code. paper clip lang kailangan and bibilangin mo lang blink nung CEL (aka MIL)
Tsikot Member Rank 5
- Nov 2003
- 3,849
October 11th, 2005 12:08 AM #8starting next week, we'll have a obd2 scanner plus car specific (bmw, benz, volvo, audi, etc) diagnostic tools in the shop. feel free to drop by
- Nov 2003
- 3,849
high idle RPM at engine start
