Results 11 to 13 of 13
- Nov 2006
- 299
April 29th, 2008 11:50 PM #11no,all codes that sat as history are no longer active,its just telling you that the ecu encountered problem previuosly.unless that concerned reappear, then it will, but this time is as current.
April 30th, 2008 07:18 AM #12
Baka accessories/acc lang and on at hindi ignition/ig.
Nonetheless acc can still drain the battery because of pilot lights and sound system.
Its also possible na charge light lang yung nakita mo.
If its really ignition that was turned on, did you ask him why does he have to leave it on?
Sir Dennis is correct the ECU/ECM must always have enough power for it to run operations if not it will not let the engine run or shut it down (sometimes derate or limp)
Tsikot Member Rank 5
- Nov 2003
- 3,849
May 4th, 2008 04:54 PM #13if that's the case just remove the battery for 30 seconds and it shouldn't happen again.
Xiaomi E-Car
