Results 1 to 20 of 27
Threaded View
    Apr 2005
    Quote Originally Posted by dembi
    My check engine light has lit up! What could possibly the reason?
    I've check the oil in the engine and the dip stick indicates that its between the min and max levels. I think this is ok. All other fluids like the brake and power steering fluids are at max level. What else could be the problem?
    Thanks!
    hello dembi!
    what car do you drive? I experienced this with my new toyota after checking that all is fine. the dealer told me to disconnect the negative pole of the battery for 3 mins to reset the error message. if problems still persist I suggest you have it checked immeditely baka me problema talaga..
Check Engine light is on!
