Results 1 to 17 of 17
    Dec 2002
    tanung lang po......
    kailangan bang sundun ung nasa manual ng car sa pag change oil kahit na d pa naabot ung rrequired distance. kc po we have a civic 2001 changing of oil is in interval of 10,000 or 6 months. e naka 15,000 pa lang mileage ng car after 1year 6 months of use. d pa ulit napa change oil since 10,000 of mileage,
    In my opinion it would be better to change your oil kahit di mo pa naabot 10k. :D
    I usually don't follow the month/time intervals if i don't go way over it... but 1 year and 6 months with the same oil (especially if it's mineral based), i think you should go for a change oil na.
    yup...correct. having a change oil din naman is cheaper than replacing your engine eh. i think it is best not to go with the distance required in your manual.
    jun, fully synthetic ang langis na nire-require ng Honda dealership ngayon para sa bagong Civic(pati yata CRV) kaya every 10, 000 ang change oil interval. Kung di ako nagkakamali, langis ng Shell na fully synthetic lang ang pwede mong ilagay sa kotse mo kapag sa casa ka nagpa-service.
    IMHO, kung sa labas ka na lang magpapa-change oil, every 5,000 km ang safe na interval specially if you are not using fully synthetic. Alaga din naman makina kahit mineral based lang. Di yata practical kapag susundin mo yung 6 months interval, magpapalit ka ngayon ng langis, tapos papa-service ka ulit sa casa pagdating ng 20,000 km. Di rin maganda kung magpapapalit-palit ka ng oil from fully-synthetic to mineral then to fully synthetic again.
    this might also help: http://www.caltexoils.com/Caltex+Internet/Any+Questions/?fbmenu=true
    Question: The recommended oil change period for my car is 10,000 km. However, I only do short trips and it takes me over a year to do this mileage. Should I change my oil before I reach 10,000 kms?
    Answer: Yes the oil should be changed earlier. The reason is that the regular short trips with stops and starts, particularly in cold conditions, is the most severe service that an oil and an engine must withstand. Short trips means that the engine remains relatively cool and so contaminants such as water condensation and unburned fuel can enter the oil sump. Also, the greatest amount of engine wear occurs at cold start-up.
    In order to set reasonable oil change periods, the manufacturer quotes both a time and a distance figure and the oil should be changed at whichever comes first.
    Dec 2002
    With Havoline Energy is it ok to have 10000K intervals in between changing the oil ?
    energy? i don't think that this will last upto 10,000... mga 6,000 or such pwede pa...
    Quote Originally Posted by jun
    jun, i also have a 2k1 civic, every 10K ako magpa-service and mga 10 months ang interval. i use full synthetic oil (caltex havoline).
    sa honda shaw and honda qc pwede ka magdala ng sarili mong oil kung ayaw mo sa kanila bumili. my ofcmate had his 2k1 serviced at honda manila and they recommended mobil1 oil.
    jun, mag pa oil change ka na. Pareho tayo ng situation, I've had my last oil change Nov 2001 16500kms mileage ko noon, sa ngayon 20400 pa lang mileage ko after 1 year. I used Mobil 1 tri synthetic then pero kahit di man lang ako umabot sa 5000kms which is 1/2 na recommended na kms. na interval ng oil change for fully synthetic oil e nagpa-change oil na rin ako dahil nga over 1 year na yung langis na gamit ko. Tama nga its better na gumastos ka sa pagbili ng langis kesa gumastos ka sa pag pagawa ng makina
    Dec 2002
    sori, ngaun lng ako naka reply.....
    salamat po sa mga replies nyo........
    pachange oil na rin pala ako bukas. mahirap na bka imbes na sa oil ako gumastos e sa makina pa.
    mga peeps,
    magpapachange oil ako. auto ko ay 98 civic lxi. ano dapat po dapat na oil ang ilagay? wala akong alam sa mga ganitong bagay e. im just a newbie. saka saan po magandang mag pachange oil dito sa amin sa cavite???
    salamat in advance!!!:wink:
    hey fLaKeZ, san ka sa cavite?
    oks lang ang havoline formula kung namamahalan ka sa energy. buy ka sa handyman mas mura, P460 yata yung formula na 4 liters then paservice mo sa mga caltex gas station.
    dito nga pala kami sa gen tri at meron kami mechanic pero on weekends lang availability and kilangan schedule kapag may papagawa. for change oil eh sa caltex gas station na lang. don't overfill nga pala and make sure that their air has a filter or wag mo na lang pahinginan para pwersahin madrain ang oil. also, they will usually offer you to use engine flush. it's up to you... ako i don't. i'm not comfortable with the contents of those engine flush. ipunin mo na lang sobrang oil every oil change then next time yun gamitan mo pang flush.
    zildjian,
    dito ko sa may bacoor. baka dito na nga lang ako sa mga caltex gas station na malapit sa amin magpaservice. ano nga pala yung engine flush??
    :salamat sa reply tol.:D
    Ako pag dating sa oil change 3k miles or 3months which ever comes first. Pag synthetic naman 5k miles.
    FLakeZ :
    Ang engine flush naman eh ginagawa kasi chances are, when your engine was new it delivered the power and fuel efficiency it was designed for. But now, as your engine accumulates miles, things are happening that are adversely affecting its performance. Slowly but surely, your engine is gathering harmful deposits that will eventually cost you money.
    Even though you may follow a routine service schedule, your driving conditions may be far from routine. Lalu na atin diyan sa pinas Stop and go driving, maalikabok, prolonged periods of idling, short trips that don't allow your engine time to warm up, the ingestion of airborne dirt tulad diyan sa maynila, fuel dilution, water condensation, and oxidized oil will eventually cause the formation of a thick, gummy deposit known as sludge. Settling throughout the engine, sludge will clog oil passages, restricting the flow of oil to vital engine parts, especially in the upper valve train areas.
    gawa ng sabi ni DY3JRM.
    parang magmumumog yung makina para matanggal yung mga contaminants.
    salamat sa mga reply tol!!!!:mrgreen::mrgreen:
changing oil
