Results 1 to 8 of 8
- Jan 2011
- 262
April 9th, 2011 02:55 PM #1Yesterday, everything was working just fine. The CEL switches off in 5 seconds or less, but after raining today, the CEL turns off 5 minutes after.
BTW, my car is parked outside so it was drenched in the rain...
This also happened to me a month ago when I washed my car, but after a day or two, it went back to normal.
Can anyone explain why this happen? TIA...
- Jun 2005
- 3,774
April 9th, 2011 03:04 PM #2it would help if d car make and model would be indicated...
anyway, it is a wiring problem. may nabasang wire or sensor. check under d hood for watermarks that would tell kung san nababasa. you can also have the ecu scanned
- Jan 2011
- 262
April 9th, 2011 03:07 PM #3
- Jun 2010
- 258
April 9th, 2011 03:26 PM #4tama sila paps either wiring, sensor, or ecu or fuse. dalhin mo lang sa auto electrician mahirap mag DIY lalo na pag electrical
- Jan 2011
- 262
April 9th, 2011 03:34 PM #5
April 9th, 2011 05:17 PM #6
April 9th, 2011 09:59 PM #7
Tsikot Member Rank 4
- 2,716
April 9th, 2011 10:43 PM #8replacing all the few electrolytic capacitors on the ECU might just fix your problem as some other owners experienced
but capacitor problem does not explain what appears to be temperature dependent symptom in your case ... so this is just a try-if-it-works approach and it won't hurt your wallet
If Mitsu prices this above 1.4M then buyers will flock to either the Corolla Cross hybrid, the...
Mitsubishi Xforce
